Date/Time: Fri, 24 Jan 2025 00:49:06 +0000
Help with Sierrachart (Bitmex)
View Count: 712
[2018-05-31 16:29:18] |
User452429 - Posts: 20 |
Hello. Sierra are not working correctly now. Do you can check my accont? I'm using Sierra for Bitmex. I have 64 bit and 32 bit versions. And anyone don't work correctly. Thanks in advance
[2018-05-31 16:32:13] |
Describe what the problem is.
[2018-06-01 09:33:41] |
Hello. Thanks for answer. This was a problem with Bitmex, but at first time admin from Bitmex said, that all are working. Problem already solved. Sorry for disturb. Have a nice day!
[2018-12-22 21:09:18] |
Hello. Can you help me? I try to login in SierraChart prog, but receive a message: Timeout error. There was no response. What can I do in this situation? Thanks in advance.
[2018-12-23 17:24:31] |
We apologize for this. It might relate to this: NOTICE: Sierra Chart Website Was Down (Outage) Can you let us know if you still have a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
