Date/Time: Mon, 20 Jan 2025 08:32:16 +0000
How to draw charts using Hong Kong stock data I get from my Interactive Brokers account
View Count: 1352
[2018-05-31 14:29:35]
User216982 - Posts: 12
I trade Hong Kong stocks. I have subscriped data feed on Hong Kong stocks through Interactive Brokers (IB).
I have connected Sierra to IB and able to draw charts on US stocks. However, I cannot find the HK stocks data in Sierra.
Please let me know how I can draw charts on HK stocks using data feed from IB.
Tkx!
[2018-05-31 19:48:43]
You need to use the proper symbols for Hong Kong stocks. Refer to:
Interactive Brokers Symbols: Stock Format
[2018-06-01 01:55:13]
Thank you for your reply.
I have tried using a seperator "/" and "." without success.
can you give me exact successful example (eg. HSBC I should use 5/HK or 5.HK)
I have used 0005/hk and 0005.hk and 00005/hk and 00005.hk and 5/hk and 5.hk.
Looking at Sierra mapping on IB I do not seems to see HK stocks. Do I need to do special mapping or is it automatic done by Sierra?
Date Time Of Last Edit: 2018-06-01 02:41:02
imageScreen Shot 2018-06-01 at 10.00.39 AM.png / V - Attached On 2018-06-01 02:02:58 UTC - Size: 2.27 MB - 381 views
imageScreen Shot 2018-06-01 at 10.00.42 AM.png / V - Attached On 2018-06-01 02:03:22 UTC - Size: 2.27 MB - 278 views
[2018-06-02 08:36:12]
Here is the symbol to use:
5-STK-SEHK-HKD
This is the format you want to use:
https://www.sierrachart.com/index.php?page=doc/IBSymbols.html#StocksWithSpecifiedExchangeAndCurrencyCodeFormat
