Date/Time: Sun, 24 Nov 2024 08:18:12 +0000
SC login error
View Count: 1482
[2013-10-11 15:42:47]
User402501 - Posts: 1
Hi, when I login to start SC pop up this message: "SC login error" (wiew the file here attached). What's the problem? How can I solve it?
imageSC login error.PNG / V - Attached On 2013-10-11 15:41:00 UTC - Size: 243.42 KB - 440 views
[2013-10-11 15:56:16]
Most likely this is due to Internet Explorer set to be working off-line.
Refer to the instructions here:
https://www.sierrachart.com/index.php?l=doc/LoginInstructions.php#LoginProblems
Date Time Of Last Edit: 2013-10-11 15:56:29
