Date/Time: Mon, 20 Jan 2025 04:06:53 +0000
Quoteboard - Change from Open %
View Count: 715
[2018-05-29 13:57:23] |
User852663 - Posts: 21 |
Any idea why this always shows 0? The Open field also shows 0 which I assume is related. It doesn't matter the time of day or symbol, I always see 0 in that field. Being able to see the % change from the open on the quoteboard would be a huge help. See attached. Ver 1745 64bit (Although I never remember this working) Date Time Of Last Edit: 2018-05-29 13:58:17
Capture.PNG / V - Attached On 2018-05-29 13:57:09 UTC - Size: 17.99 KB - 263 views |
[2018-05-29 19:00:32] |
We see you are using Transact and the Open price is not being provided in this case.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-29 19:00:43
