Date/Time: Mon, 20 Jan 2025 04:10:17 +0000
Partial missing data on cumulative delta study (volume) for symbol EX#
View Count: 1048
[2018-05-29 10:38:04] |
User91600 - Posts: 1 |
On the cumulative delta study (volume) for symbol EX# the data flatlines specifically between 7/2/18 and 21/5/18, all my other charts relating to this symbol are fine, including cumulative delta up/down tick, I have deleted and downloaded data a number of times - the corresponding chart for symbol XG#, which is also from EUREX is OK - Any ideas ?
[2018-05-29 11:23:44] |
Refer to: DTN IQ Feed Data Service: Tick Data Limitation during Primary Session Hours You should consider using the Sierra Chart Exchange Data Feed instead: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-29 11:23:54
