Date/Time: Mon, 20 Jan 2025 04:09:08 +0000
SC Simple moving average difference from other platforms
View Count: 1357
[2018-05-29 07:55:43]
bodzhar - Posts: 17
I've noticed the SMA studies in SC vary dramatically from other charting platforms.
For instance at market open 05-25-18 the daily chart 200SMA for US stock, $GPS was 30.98 on SC. On TC2000, Esignal, Tradezero and Tradingview the 200SMA on the same daily was 30.00. The figures were just as skewed at the end that day.
The 100SMA, same time frame, stock and date it was, SC 31.27. Tradezero, Tradingview and TC2000 all 31.70.
They are significant differences to what all other charting platforms I can access were showing. Is it something on my end causing them to show so differently?
[2018-05-29 18:51:45]
This section here may be helpful:
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#ResolvingStudyDifferences
Make sure you are determining the values of the moving average properly through the Chart Values tool. Refer to:
http://www.sierrachart.com/index.php?page=doc/Tools.html#ChartValues
The other issue could be that the historical data in Sierra Chart is either adjusted for dividends or not. There is a setting for this:
http://www.sierrachart.com/index.php?page=doc/helpdetails12.html#DifferencesWithHistoricalDataDueToDividendAdjustments
Date Time Of Last Edit: 2018-05-29 18:52:08
