Date/Time: Sun, 24 Nov 2024 08:23:25 +0000
Qeustion
View Count: 1282
[2013-10-11 11:43:09] |
User69935 - Posts: 3 |
Can get no connection with Openecry i have enabled the setting on Openecry and disabled the firewall
2013-10-11 12_37_24-Message Log failer.jpg / V - Attached On 2013-10-11 11:42:31 UTC - Size: 183.81 KB - 442 views |
[2013-10-11 15:37:09] |
Follow step 9 here: http://www.sierrachart.com/index.php?l=doc/openecry.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
