Date/Time: Sun, 26 Jan 2025 06:49:45 +0000
Limit if Touched - Client order
View Count: 1870
[2018-05-29 04:54:25]
dd78746 - Posts: 22
"The General Trade Settings option HoldLimitAttachedOrdersOnClientSideUntilTouched has been removed as it is no longer necessary now that there is the Limit if Touched - Client order which effectively does the same thing. This is what is recommended to be used as the alternative. If there is any functionality which you cannot accomplish now that this option has been removed, let us know and we will see how best to implement this."
Can the "Limit if Touched - Client order" feature be made available for Stop Limit orders?
TIA
[2018-05-29 19:28:58]
Do you mean a client-side managed Stop Limit order? That can be added.
[2018-05-29 19:33:59]
dd78746 - Posts: 22
Yes, I mean a client-side managed Stop Limit order. THANKS!
[2018-05-30 05:39:50]
Okay we will see about adding this one.
[2019-02-12 11:02:47]
ARDAN - Posts: 66
Dear Support,
In Trading window there are "Limit If Touched order" and "Limit If Touched-Client" Order.
When I want to add
"Buy Limit If Touched" and "Sell Limit If Touched" commands via "customize chart trade menu" I can't find these two. Could you please add them as well?
Thanks.
[2019-02-12 20:13:17]
Is Limit if Touch supported by the trading service you are using? This is not a commonly supported type. It really does not make sense for us to add these commands.
[2019-02-13 07:17:34]
ARDAN - Posts: 66
Good point. Thanks.
