Date/Time: Mon, 20 Jan 2025 04:15:33 +0000
Customizable text message on a chart when certain conditions met
View Count: 742
[2018-05-28 18:25:01] |
User718694 - Posts: 25 |
Hi, what's the way of putting a custom, static message (fonts, chart location) when a certain conditions (MAs crosses, price location against those MAs) are met?
[2018-05-28 21:25:58] |
Yes this is supported with the Color Bar Based on Alert Condition study. Refer to the detailed instructions for this here: Color Bar Based on Alert Condition: Drawing Arrows/Text or Other Styles at the High or Low of Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
