Date/Time: Mon, 20 Jan 2025 03:58:13 +0000
Open Office Calc - Not Excel
View Count: 668
[2018-05-28 15:50:35] |
User623552 - Posts: 69 |
Hi, I'd like to use openoffice calc instead of Excel I've seen that you support calc When I use the spreadsheet system/alert study, there is only an option for excel When I set that to 'yes', I get the following error : "unable to start excel" How can I get it to start calc instead of excel ? I have searched the documentation and support board, also all the settings in the software However, I'm struggling to find the correct option/settings Thanks |
[2018-05-28 19:25:31] |
This is not supported.
