Date/Time: Mon, 20 Jan 2025 04:09:40 +0000
What does Trade Window 'Set' Tab > Trig Limit Offset do?
View Count: 969
[2018-05-28 07:20:09] |
User605373 - Posts: 1 |
In the Trade Window 'Set' Tab, there is a checkbox for "Trig Limit Offset". What does it pertain to? In the relevant documentation (http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#TradeWindowSetTab ) this particular check box is missing. The Buy Limit if Touched order needs two prices: the limit price and the trigger price. If I use "Buy Limit if Touched" from the (right-click) Chart Trade Menu, which of the two will I have selected, and where do I set the other one? Am I right in assuming that by right-clicking on the chart, I will have chosen the Limit Price, and the trigger price is automatically set using this "Trig Limit Offset" setting on the 'Set' tab? Date Time Of Last Edit: 2018-05-28 08:28:11
[2018-05-28 21:39:00] |
Refer to the Limit if Touched documentation here: http://www.sierrachart.com/index.php?page=doc/OrderTypes.html#LimitIfTouched And we realize that there is an extra price setting you will see for Limit if Touched when entering that order from the main trade window which should not be there and it is going to be removed in the next release. It is not used. We also recommend using Limit if Touched-Client instead: http://www.sierrachart.com/index.php?page=doc/OrderTypes.html#LimitIfTouched-Client Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-28 21:39:41
