Date/Time: Sun, 24 Nov 2024 09:07:44 +0000
Flex Renko Bar
View Count: 1381
[2013-10-11 10:46:48] |
setapakforex - Posts: 10 |
Date Time Of Last Edit: 2013-10-12 10:19:59
[2013-10-11 15:54:53] |
Yes you can. Do see a problem with this? If so provide an image of the chart, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
