Date/Time: Mon, 20 Jan 2025 04:07:28 +0000
[Programming Help] - Looking for Bitmex help ( exchange problem)
View Count: 742
[2018-05-28 06:48:14]
User651753 - Posts: 77
Looking for help to better trade on bitmex.
Like everyone, I am getting errors because bitmex is having problems, Lag, cant place order
is there any setting I can change to fix up? ( I Prefer the DTC as I tested 2 system with DTC and API and the API was worst)
Is there a setting to keep re-sending the action until it gets through? ( Eg resend every 1 min for a max of 5 min)
Is there a way to implement bitmex dead man switch https://www.bitmex.com/app/wsAPI#Dead-Mans-Switch-Auto-Cancel ( at least this will cancel the order)
One way I have managed to get around this with a spreadsheet:
1. Build your system eg on 1 hr .... then use the
study/price overlay
study and place all the study on a 1 min chart
2. Within the spreadsheet setting, limit only ONCE per direction...
3. Build the Spreadsheet system to keep trigging K3 every candle until reversal,
I've also made a so it will only keep triggering order if the count is less then eg 10
=IF(p3, 1, u4 + 1)
k3 =
=if(u3<10,p3,0)
at least doing this - if there is an error it will try on every candle after, and if it does not enter a trade after 10 min of first triggering entry, it will stop sending an order.
Is there a way to chart on less then 1 mim ?
can you use a spreadsheet to trade on 10 sec ?
