Date/Time: Mon, 20 Jan 2025 14:00:22 +0000
did you stoped working with AMP futures?
View Count: 2751
[2018-05-27 18:52:02]
User61576 - Posts: 445
I could not find it in the Supported Data and Trading Services page but on their website they do show they offer SC
[2018-05-31 16:28:30]
AMP is supported:
https://www.sierrachart.com/index.php?page=doc/OtherSitesLinks.php#Brokers
[2018-05-31 16:51:47]
I am sorry. there are so many options here I got lost.
there is no setup for AMP. I understand I will need to connect it to Rithmic and CQG to trade with AMP?
can I connect to SC live feed as a data provider and AMP as a broker?
where are the instructions? I only found a help page to connect with Rithmic/CQG but not AMP
[2018-05-31 19:47:10]
Here are the Rithmic and CQG setup instructions:
Rithmic Trading Platform Service: Setup Instructions
CQG Trading Platform Service: Setup Instructions
Yes.
Date Time Of Last Edit: 2018-05-31 19:48:01
[2018-06-03 04:48:49]
Yes.
so how do I connect to SC data feed and to AMP to trade?
[2018-06-03 07:43:56]
Do you know if AMP has set you up with the Rithmic or CQG trading platform service? We need to know which one.
[2018-06-04 10:56:19]
now I understadn that i will need to approch them (AMP)
which way will be the min. cost (if you know)?
will the SC data feed be reuced this way? or the only way is using AMP/ttnet ? this is not clear from here https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices
[2018-06-08 09:22:22]
Any answer here how to work with AMP?
[2018-06-08 09:49:28]
Most people are just using CQG through AMP. That is what we recommend.
[2018-06-09 11:22:12]
Here are the CQG setup instructions:
[2018-06-24 12:47:59]
btw, will this amp account will entitle me for reduce SC data feed? in the sc data feed documentation there is reference (https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions ) for AMP/TTNet and I want to make sure that using this method (sc data feed +amp with cqg) will be the lower price for the feed
thanks
Date Time Of Last Edit: 2018-06-24 18:22:47
[2018-06-24 18:31:00]
The Sierra Chart account you have used to post this last message with is your own account, and that will entitle you to the standard pricing for the Sierra Chart Exchange Data Feed.
And being you have a trading account, you will be able to take advantage of the lower-priced CME exchange fees.
