Date/Time: Mon, 20 Jan 2025 03:54:36 +0000
Back Test Freezing at end of session, 15M chart;
View Count: 625
[2018-05-27 16:21:56]
GiantAvocado - Posts: 67
Then the back test resumes after a couple of minutes. There is some errors in the log though, I attached a screenshot of the log.
Private File
[2018-05-28 01:02:53]
Refer to steps 8 and 9 here:
http://www.sierrachart.com/index.php?page=doc/ReplayChart.html#BasicInstructions
In regards to the error filtering, disable the error filtering as explained here:
http://www.sierrachart.com/index.php?page=doc/ErrorFilter.html
Date Time Of Last Edit: 2018-05-28 01:03:14
