Date/Time: Mon, 20 Jan 2025 08:21:05 +0000
ACSIL function to load study to chart
View Count: 1284
[2018-05-27 15:23:21] |
User99735 - Posts: 234 |
Hi, Is there an ACSIL function available, to add study to chart, from another study? Regards Vivek |
[2018-05-27 19:40:35] |
No.
[2018-05-27 20:58:17] |
Ok, any ACSIL function available to duplicate a chart or possibility of adding one?
[2018-05-29 12:53:52] |
Hi, Any update on the 'Duplicate' function request?
[2018-05-29 18:43:29] |
You can open a chart or get a reference to it, with this particular function: http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html#scOpenChartOrGetChartReference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-29 18:51:08] |
Correct, but I need a study also to be run on the opened chart. There is no ACSIL function to add a study to an open chart ( agree that setting up inputs to the study will not be easy ), duplicating an existing chart with a study, will address my requirement. The proposed duplicate function should have inputs for symbol and time frame, for the chart to be opened. |
[2018-05-29 19:31:29] |
This does not exist. It is not something we can add anytime soon. The closest you can do is to use a Study Collection which would be automatically added to a new chart. Refer to: http://www.sierrachart.com/index.php?page=doc/StudyCollections.html#AutomaticallyApplying Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-29 19:32:27
[2018-05-29 20:05:12] |
Ok, thanks. Is there any feature request page, where I can add Duplicate function as a feature request?
[2018-06-01 08:15:48] |
There is no other place to request this other than here. We will be looking at this probably next year. So it is not something to wait around for.
