Date/Time: Mon, 20 Jan 2025 03:59:07 +0000
ACSIL : change study short name / sc.GraphShortName
View Count: 967
[2018-05-27 15:15:33] |
wwwingman - Posts: 185 |
Hi, I would like to set the study short name in my code. This makes recreation of charts with tools that evolve often a lot easier for me. The problem is that the sc.GraphShortName is a readonly variable. Is it possible to add a set function in order to set a default value of the study ? Is there another way to do that that I missed in the documentation ? Thx. -- W. |
[2018-05-30 05:00:26] |
This will be supported in the next release.
