Date/Time: Mon, 20 Jan 2025 03:56:40 +0000
Numbers Bars - Ask/Bid Volume Split Profile - Set The profile widths
View Count: 1167
[2018-05-27 08:55:18] |
User618539 - Posts: 13 |
Hello, i have a question reg The profile widths in the Ask/Bid Volume Split Profile display. I have time based charts, let say 5min bars to display the Ask/Bid Volume Split Profile. I want the profile width to be set to the same lenght relative to a certain absolute number of contract across time. So lets say there are 100 contracts on the bid across different 5min bars, they should have all the SAME widths displayed, NOT relative to the volume traded within each of the 5min bars. Is there a way to set this up? TIA |
[2018-05-27 09:44:02] |
Refer to: Numbers Bars: Volume Profile Bars Length Relative to All Visible Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
