Date/Time: Mon, 20 Jan 2025 08:17:07 +0000
cross hair colour for different charts
View Count: 1278
[2018-05-26 08:44:14] |
andrew miles - Posts: 21 |
i have a number of different charts and the cross hair in some is yellow, white in others and black in others. I can no longer find where to change the crosshair colour. It would be ok but for some reason i have black on black which is not very useful. thanks It cant be a windows option as i have my mouse turn white on dark backgrounds and light on dark but its not working on the charts |
[2018-05-28 21:44:00] |
The Chart Values:* tool colors are set through the Graphics Settings. Refer to: http://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-04 03:57:51] |
that does not help me as the versions have changed and this value is no longer there so I have charts with different colour crosshairs and no way to change them on a per chart basis
[2018-06-04 05:01:52] |
and this value is no longer there The Chart Values tool color settings are definitely in the two Graphics Settings windows. That is definitive, in the latest versions. Check again.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-04 05:02:33
[2018-06-04 05:30:15] |
It is in Global Graphics but you used to be able to set the chart value line per chart not just globally
[2018-06-04 07:21:28] |
Yes this is done through Chart >> Graphics Settings as explained here: Graphics Settings: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-04 08:05:00] |
well I do not see if but can find it in global. I don't want global as I have different background charts. Its like you took it away in these latest versions
[2018-06-04 09:12:01] |
Okay we see. The programmer who worked on this, apparently did not add them there when they were supposed to be. We do not think they were ever removed. We will get this done in the next few days. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
