Date/Time: Mon, 20 Jan 2025 04:11:09 +0000
v.1750 sc.SaveChartImageToFile bit depth = 1
View Count: 664
[2018-05-25 23:15:39] |
User924791 - Posts: 12 |
I've just noticed that the PNG chart images are now black & white (bit depth 1). They used to be in color (bit depth 32). Is there some property that I need to set to get full color again? |
[2018-05-25 23:55:52] |
This will be resolved in the next release we will have out later today.
