Date/Time: Mon, 20 Jan 2025 04:10:45 +0000
Demo AMP
View Count: 1209
[2018-05-25 17:06:41] |
User403087 - Posts: 1 |
Hi, I want to start a free demo for 14 days but I have troubles to log-in with CQG. the instruction movie on the website is not clear and also with Ritmic data while I got CQG. Also you have 2 CQG possibilities but wich one to use?? Please give me some clear instructions Thanks |
[2018-05-25 19:01:15] |
Here are the CQG setup instructions: http://www.sierrachart.com/index.php?page=doc/CQGTrading.php#SetupInstructions Use the "CQG Web API" Service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
