Date/Time: Mon, 03 Mar 2025 18:28:42 +0000
high ask/low bid volume percent plot on main chart
View Count: 1346
[2018-05-25 15:57:32]
User232760 - Posts: 1
I am wondering if there is a way to plot the high ask/low bid volume percent values directly above/below the number bars instead of having them in the separate grid.
Also, is it possible to display the percentage as a decimal ratio?
[2018-05-25 18:46:34]
Look at using this particular study:
Study Subgraph As Text Above/Below Bar
It can reference the Numbers Bars Calculated Values study.
To do other calculations like you want, refer to:
http://www.sierrachart.com/index.php?page=doc/ArithmeticStudies.php
