Date/Time: Mon, 20 Jan 2025 04:03:29 +0000
[Programming Help] - Method to move alert icons on vertical axis
View Count: 681
[2018-05-25 12:51:31] |
User422943 - Posts: 1 |
Under Study Settings, Subgraphs, there is a "Displacement" option that enables moving the alert icon on the horizontal axis. Is there a way to move the alert icon on its vertical axis?
Sierra Chart Graphic.jpg / V - Attached On 2018-05-25 12:48:52 UTC - Size: 55.72 KB - 274 views |
[2018-05-25 18:50:48] |
You can do this now as explained here: http://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#ControllingTheLocationOfArrowsOrSubgraphValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-25 18:51:00
