Date/Time: Thu, 28 Nov 2024 01:36:00 +0000
Numeric Information Graph Draw Type 32 vs 64
View Count: 1123
[2018-05-24 20:44:40] |
onnb - Posts: 662 |
When opening this study on 64 bit, I don't see the Close row with BG color I do see the BG color when opening same chartbook/study on 32 bit I'm seeing this with other custom studies, this is just an example |
Private File Private File |
[2018-05-25 05:40:39] |
We could not reproduce this, but we are going to put out a new release, and we want you to recompile each of the studies on the corresponding version of Sierra Chart (32/64). We would not expect a further issue after rebuilding because we cannot reproduce it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
