Date/Time: Mon, 20 Jan 2025 04:06:22 +0000
[User Discussion] - Sierra Chart incorrect bar time
View Count: 1005
[2018-05-24 08:16:10]
chart_warrior - Posts: 96
I noticed that Sierra shows incorrect time for 1 minute bars. If you look at the screenshot you will see 2 platforms, on the left is InvestorRT with CQG and on the right is Sierra Trial. Notice how the last red bar (and all other bars) has a time stamp of 16:14, that is incorrect as this bar should have a time stamp of 16:15 because it's the last bar of the session. Symbol is ES.
Is that a matter of data feed? Clock is synchronized properly and other trading systems are showing this bar correctly as 16:15.
[2018-05-24 08:17:03]
++ screenshot
image2018-05-24_4-08-00.jpg / V - Attached On 2018-05-24 08:16:24 UTC - Size: 90.3 KB - 289 views
[2018-05-24 08:26:47]
It is important that you read the documentation here about this:
Working With Charts: Time Scale
There is definitively nothing wrong with something so basic like this.
Date Time Of Last Edit: 2018-05-24 08:27:07
[2018-05-24 09:22:11]
My session start time is 09:30:00 and end time is 16:14:59 for day session only. I'm not sure what needs to be changed in order for all bars to be shifted 1 minute forward.
[2018-05-24 09:33:59]
OK I see that this is the way Sierra does it (Differences With Data and Chart Bars Between Services / Connections / Chart Types: Chart Bar Time Stamping is Start of Bar) but when comparing studies and other things with other people who use different platform it is very inconvenient.
Is there a way to change it?
