Date/Time: Sun, 24 Nov 2024 07:50:44 +0000
[User Discussion] - specific order of minimized charts, mixed up every time
View Count: 1772
[2013-10-10 21:13:04] |
BataviaTrader - Posts: 63 |
I have 4 smaller charts in one window. I have these in a particular order (like from low time frame to higher time frames) . But after maximizing and then switching back to smaller, the order is mixed up every time. How to have the particular order fixed so I don't have to re-order / re-arrange my little charts every time? I have tried the Reset Windows function, but it does not do what I want. Please advice if you have time. Thank you in advance. |
[2013-10-14 17:17:32] |
This may not help you, but you can change the order of charts through Window >> Windows and Chartbooks. We cannot offer any further help than this, as what you are describing is something controlled by the operating system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-14 17:18:28
