Date/Time: Mon, 20 Jan 2025 04:13:37 +0000
compact tool values window
View Count: 1080
[2018-05-23 19:26:51]
Glenn Infinity - Posts: 103
can the fields in the compact tools window be altered?
is there any way to add the range value (hi - low for the bar/candle) to the window?
[2018-05-24 00:01:57]
The way to do this is to add the Bar Difference study to the chart and then when using the Tool >> Chart Values in the chart region containing this study, this value will then be visible.
Here is the documentation for this study:
Bar Difference
