Date/Time: Mon, 20 Jan 2025 04:05:35 +0000
Indicator shows completely different data on different computer
View Count: 699
[2018-05-23 16:21:13]
User992452 - Posts: 1
I am using Sierra on my Notebook and on my PC with the same log in and same data feed. Unfortunately the Cumulative Delta Bars - Up/Down Tick Volume Open study shows completely different results on my PC then on my Notebook. Also the charts aren't the same. Just compare the bars. Should't the study and charts show pretty much exactly the same while using the same data feed on both?
You can see pictures at the attached file.
Regards
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=19409
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=19410
[2018-05-23 17:59:45]
We do not accept the type of screenshots you provided.
You need to follow the instructions here:
For resolving the problem, refer to:
Cumulative Delta Bars - Volume: Resolving Cumulative Delta Bars Differences
Date Time Of Last Edit: 2018-05-23 18:00:53
