Date/Time: Sat, 28 Dec 2024 16:31:38 +0000
Tradestation Data
View Count: 1950
[2013-10-10 20:31:07] |
buylosellhi - Posts: 60 |
Hi, Is it possible to use tradestation datafeed in Sierrachart - kinda like how its possible in Ninjatrader and Multicharts ? thx |
[2015-01-07 19:16:13] |
startledbymoth - Posts: 39 |
I do not see a SC response to this post, and I have the same question. Please advise, thanks.
[2015-01-07 19:44:20] |
No.
[2016-01-17 12:59:06] |
User387334 - Posts: 5 |
It is now a year later, has this changed? An email I got from a rep with PTS Chart Analyzer service said I will be able to use my TradeStation datafeed with their Sierra Charts package. I am trying to confirm this can actually be done before signing up. Please advise if the status has changed. Thank you.
[2016-01-17 21:45:18] |
Nothing has changed about this and never will do to the very pathetic and greedy nature of this industry. Trade Station should consider adopting the DTC Protocol: http://dtcprotocol.org/ Also Sierra Chart has its own DTC Protocol Server to share any data feed including the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-18 02:03:02] |
Thank you very, very much. I appreciate your taking the time to give me the information I need. I understand your point. It's tough out there. :)
