Date/Time: Mon, 20 Jan 2025 04:12:41 +0000
Stop loss
View Count: 939
[2018-05-23 10:54:59] |
User00111 - Posts: 111 |
Is it possible to put the stop loss after placing an order? Today and it happened to me that inadvertently after placing a buy order I cancelled the stop ... wanting to put it back is possible? |
[2018-05-23 12:07:29] |
Zdislav - Posts: 73 |
Yes, it is possible, but you have to set something at first. Take a look at this link - https://www.sierrachart.com/index.php?page=doc/OrderTypes.html#SendAttachedOrders. Z. |
[2018-05-23 12:15:37] |
I had already read it, but I did not find anything about it
[2018-05-23 15:16:18] |
Xfanman1 - Posts: 320 |
Antonio, here's what I do. I've added these trade commands to my Chart Sub Menu (see image). If I select Sell Stop when I'm long or Buy Stop when I'm short it will place a stop order wherever my cursor is placed and I can adjust it from there. -- Scott |
[2018-05-23 15:37:40] |
Or you can do it like this... Menu >> Global Settings >> Customize Chart Trade Menu (see trademenu.png) ...and add the option to the menu (see trademenu2.png) ...and with Chart Trade Mode On you can send attached orders as preset in Trading Window (see sendorders.png) And you can set ACS button to it as well if you wish. Z. Date Time Of Last Edit: 2018-05-23 15:44:17
trademenu.png / V - Attached On 2018-05-23 15:32:00 UTC - Size: 22.22 KB - 276 views sendorders.png / V - Attached On 2018-05-23 15:34:42 UTC - Size: 26.24 KB - 297 views trademenu2.png / V - Attached On 2018-05-23 15:35:32 UTC - Size: 14.48 KB - 294 views |
[2018-05-23 18:41:34] |
Here is the relevant documentation for this: Order Types: Send Attached Orders - Position/Price Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
