Date/Time: Mon, 20 Jan 2025 03:54:56 +0000
Reference all previous bars in a session
View Count: 688
[2018-05-23 09:14:16]
chart_warrior - Posts: 96
I'm trying to create a signal that will show me when one study is making a new low and another doesn't.
For example:
When TICK is at low of day and CL(crude) is not. Basically looking for divergence.
I know I can use low of day with OHLC but that shows me whatever the last low of day was. I need to see when the bar is currently at low of day compared to all previous bars. I hope it makes sense.
[2018-05-23 10:05:22]
User651753 - Posts: 77
you could use 2 charts ... and use a spreadsheet ( will show both study)
Referencing Other Charts in Spreadsheet Study Formulas
then just have a buy signal ( arrow) when it meets your criteria one low and one not low
[2018-05-23 18:16:08]
See if this study can be used to help to do what you need:
Study Subgraph Daily High Low
[2018-05-24 00:47:27]
Thanks, I was able to use Subgraph Hi/Lo and it's working now.
