Date/Time: Mon, 20 Jan 2025 04:09:13 +0000
Chart without Globex Data
View Count: 602
[2018-05-23 02:32:11] |
John R D - Posts: 25 |
Hi, How can I construct a chart without globex data? I just want the RHT session. John |
[2018-05-23 04:19:36] |
This is done by adjusting the Session Times settings for the chart. Refer to: http://www.sierrachart.com/index.php?page=doc/SessionTimes.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-23 12:49:23] |
Thanks. Is there a setting so a chart can be always on top?
[2018-05-23 17:50:29] |
If the chart is detached, yes. Refer to: http://www.sierrachart.com/index.php?page=doc/DetachingandAttachingChartWindows.html#SettingDetachedChartToBeAlwaysOnTop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
