Date/Time: Mon, 20 Jan 2025 03:58:42 +0000
Spread chart months
View Count: 604
[2018-05-23 02:19:54] |
User435059 - Posts: 14 |
Hello !!! i wonder if possible to create symbol Chart only from specific symbol month ? like CL ## continuous contract 10 years long only from December or any month i chose ? and one more if possible to export market data to file or external database ? |
[2018-05-23 04:28:07] |
Yes this is supported. You need to use this particular Continuous Futures Contract option: http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html#ContinuousFuturesContract_RolloverEachYear_SameMonth For instructions, refer to: http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html#UsingContinuousFuturesContractCharts To export data, refer to: http://www.sierrachart.com/index.php?page=doc/ImportExport.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
