Date/Time: Mon, 20 Jan 2025 04:09:41 +0000
connect directa.com
View Count: 1116
[2018-05-22 16:28:44] |
User266653 - Posts: 1 |
Hello, Please, How do I link Sierra to Darwin2 or Multicharts, or to tradingwiew or ViewTrade? These applications are provided by my broker www.directa.com. Thank you. |
[2018-05-22 18:38:53] |
What type of link are you looking for?
[2018-05-23 16:19:21] |
Sierra Chart - Max - Posts: 5779 |
From User: I wish to link my account to directa.com broker.
Display data and send commands. In the DARWIN platform there is some setup via the API, I do not know how it is set up and whether it is supported by you. Sierra Chart Support |
[2018-05-23 18:38:38] |
This is not supported.
