Date/Time: Thu, 26 Sep 2024 23:31:11 +0000
Draw Volume Profile Tool
View Count: 6293
[2018-05-22 15:44:21] |
User153269 - Posts: 7 |
Hello, Would it be possible to add the functionality to save different Tool Configs for the Draw Volume Profile tool? I prefer to keep my default volume profile settings different from the ones I commonly use when drawing a custom volume profile and it would be very helpful to be able to save the configs separately. Perhaps this functionality already exists and I'm just not aware of it. I understand it is probably not a high priority issue, but figured I'd make the suggestion. Thanks Date Time Of Last Edit: 2019-01-17 00:15:57
[2018-05-22 18:46:52] |
Zosimus - Posts: 345 |
+1
[2018-05-22 18:56:57] |
This is supported and is explained in these detailed instructions here: Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool This is done through Study Collections as explained. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-22 18:57:27
[2019-04-05 13:35:02] |
User164231 - Posts: 278 |
Yup, awesome to save and click Analysis to select the type of VP you want. Can we include a simple VP function which color the profile based on time? (similar to TPO) It is very useful to provide info of price action without looking at candle. Please help. |
