Date/Time: Sun, 19 Jan 2025 21:47:08 +0000
TPO charts with zooming feature and volume per 30 minute period
View Count: 1360
[2018-05-22 14:07:29]
User169041 - Posts: 7
Greetings Sierra engineers!
In any future upgrades, is there going to be a zooming feature for TPO's? Because, currently, you have the scaling options but that does not work good. Even if I scroll the chart in, the TPO's look crunch up. I know that with Windotrader you have that feature. (just a hint.) Also, having the option when you split the profile to be able to see the volume per period.
Just my thought on improving on a software that has everything.
Thank you for your time.
Johnny
[2018-05-22 18:41:43]
This is currently supported by adding the Volume by Price study. Refer to:
http://www.sierrachart.com/index.php?page=doc/StudiesReference/TimePriceOpportunityCharts.html#VolumeProfiles
The Volume by Price study added to the chart can be set to display the total volume as text:
http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=141#Input_DisplayEntireProfileVolume
Date Time Of Last Edit: 2018-05-22 18:43:34
