Date/Time: Sat, 26 Apr 2025 09:46:35 +0000
Quote Board
View Count: 1848
[2018-05-22 11:47:26]
User620704 - Posts: 20
Is there a way to create a quote board all at once instead of adding the symbols one by one? Say I just want all the Bitfinex symbols on a quote board. How do I do this automatically?
[2018-05-22 12:16:35]
Acro - Posts: 442
Create a text file with the list of symbols on separate lines and import that as a symbol list.
It then becomes one step
[2018-05-22 13:06:06]
Yeah, I thought maybe I could copy and paste from the symbol list but it's not an option?
[2018-05-22 17:57:49]
As Acro stated, you can import a list of symbols. You will find the documentation for this here:
Getting Quotes: Saving/Loading Symbol Lists and Importing Symbols
[2018-05-23 12:06:27]
I think my follow up question was not specific enough. I understand now that I can import a list of symbols. My issue is how to quickly create a list of symbols to import. For example, as noted in my initial post, I'd like to just quote board the entire Bitfinex list of symbols but I don't see a way to turn that into a text file? Is there a way? I do not see a way in the link above?
[2018-05-23 17:44:26]
We really cannot think of a way. The symbols do exist in the GlobalSymbolSettings.XML file in the Sierra Chart installation folder. You can extract them from there.
[2018-06-01 04:02:54]
Actually thinking about this some more, Bitfinex symbols do not exist in this file. They are retrieved remotely.
Date Time Of Last Edit: 2018-06-01 04:04:16
