Date/Time: Sun, 24 Nov 2024 08:26:44 +0000
[User Discussion] - Numbers Bars Study ~ "Volume imbalance"
View Count: 3342
[2013-10-10 18:01:51] |
User96105 - Posts: 113 |
Hi Sierra Support. MarketDelta have a Footprint type called Volume Imbalance. Brief description in attached .pdf file. Is it possible to replicate this with the Numbers Bars studies? Thanks |
Imbalance.pdf - Attached On 2013-10-10 18:00:34 UTC - Size: 285.18 KB - 2003 views Attachment Deleted. |
[2013-10-10 18:10:21] |
ganz - Posts: 1048 |
User96105 http://www.sierrachart.com/supportboard/showthread.php?t=36699 |
[2013-10-10 18:13:11] |
SgtJ - Posts: 154 |
Sierra put this option out over a yr ago if I remember correctly...how do you think OFA came up with the idea, lol.
[2013-10-10 18:24:38] |
SgtJ - Posts: 154 |
you're too fast ganz :)
[2013-10-10 18:44:31] |
mkata - Posts: 103 |
Thanks for asking this question, I've been wondering about the exact same thing lately, looking to add more order flow information into my trading.
[2013-10-10 18:45:41] |
SgtJ sorry, sir next time when i'll see your stuff i'll give you a couple of weeks to answer :)) |
[2013-10-10 20:00:55] |
Great, thanks guys. Looks like I need to use "Text on Dominant Side Auction". I need to spend some time getting my head around the many parameters....
[2013-10-10 21:29:11] |
User96105 i've shared the expml on bmt https://www.bigmiketrading.com/sierra-chart/29007-ofa-sierra-chart.html |
[2013-10-11 10:02:56] |
That's very helpful, thanks ganz. Just a couple of issues I'm having ~ the Chartbook isn't loading and I'm getting a log error "unable to read newer Chartbook file format..." (I'm on the latest SC version). Also it seems to be trying to open a data link to eSignal (I'm using Rithmic). I've tried the Scan study, and that looked fine, but now the marker is solid colour and I can't see the numbers behind!! Sorry for taking up your valuable time |
[2013-10-11 10:19:34] |
User96105 u r wlcm the Chartbook isn't loading and I'm getting a log error
it was built yesterday w 1032 non-CLR version /08.10.2013/ so looks like you need to wait for new release: 1033 or higher a data link to eSignal (I'm using Rithmic)
no, it is CTS T4 /my live account/ you will need to do F5 -> Symbol -> Find to change the data source now the marker is solid colour and I can't see the numbers behind!!
F6 -> and move up/down the studies in the list Date Time Of Last Edit: 2013-10-11 10:20:52
[2013-10-11 11:39:52] |
Brilliant! All works having downloaded PreRelease. Many thanks |
