Date/Time: Mon, 20 Jan 2025 08:32:52 +0000
Multiple Instances of Sierra Charts running DTC Bridge on a Server
View Count: 1553
[2018-05-21 23:02:32]
Highlydubious - Posts: 22
I am attempting to run two instances of Sierra Chart on my VPS. 1. Rithmic (Futures) 2. IB (currencies and stocks). I am currently using the Rithmic instance as a DTC bridge. What are the ideal port numbers for the second IB SC instance running DTC Bridge?
Also, how many instances of SC can I run under the same username? In this case, i would have 2 instances on the VPS and 2 instances on a laptop, locally. I might also want to run it on my home PC as well. Which would make 4-6 concurrent logins.
Thank you,
[2018-05-22 04:28:34]
You can use whatever port numbers you want. There are really no ideal numbers.
You can run as many instances of Sierra Chart you want under the same username on the same computer. It sounds like you will want to use three systems. So for the third system you need to enable that here:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
[2018-05-22 19:34:59]
Thank you, other than changing the Listening Port (11099) and Historical Data Port (11098). Should I also change the UDP Port (22903) and TLS Historical Data Port from 0?
Ok, I see the option to purchase a 3rd system to use. Could I do two on the same SC username and a third system on a different SC username?
[2018-05-22 20:07:00]
Following up:
Even trying different Listening and Historical Data port for my second IB SC instance. I get this:
Rithmic Trading | Connecting to the server 208.78.38.30. Port 11095 | 2018-05-22 16:03:42
DTC Client socket (67) | Creating socket. Using TLS 1.2. | 2018-05-22 16:03:42
DTC Client socket (67) | Connecting to IP: 208.78.38.30. | 2018-05-22 16:03:42
File >> Disconnect selected. | 2018-05-22 16:03:57
DTC Client socket (67) | Initiating close of socket by core. | 2018-05-22 16:03:57
DTC Client socket (67) | Closed. | 2018-05-22 16:03:57
Rithmic Trading | Disconnected. | 2018-05-22 16:03:57
It's unable to connect. It says Rithmic Trading, but it should be saying Interactive Brokers
[2018-05-22 20:15:25]
No.
If you have a second Sierra Chart account, then there is no reason to activate support for a third system.
Post #4 indicates some connectivity issue between the client and the server.
Date Time Of Last Edit: 2018-05-22 20:15:48
[2018-06-04 21:21:24]
Thank you, this is now working
