Date/Time: Thu, 24 Sep 2026 16:48:16 +0000
[Programming Help] - Conditional study language
View Count: 1005
| [2018-05-20 19:22:01] |
| User28682 - Posts: 233 |
Hi, I would like to produce an alert when: 1) High[-1]<=H[-2]and Low[-1]>=L[-2] 2) C>H[-1] OR C<L[-1] So assuming the inside bar is TRUE (1), I want it to trigger if the current bar takes out either the previous bars(inside bar) high or low (2). I did this without success: =AND(H[-1]<=H[-2],L[-1]>=L[-2]),OR(C>H[-1],C<L[-1])) I tried this and did not get an error message but so far no triggers with a TRUE: =OR(AND(H[-1]<=H[-2],L[-1]>=L[-2]),AND(C>H[-1],C<L[-1])) I need the second part of the formula to be an "OR", meaning one or the other will most likely trigger. Help! Thanks! Date Time Of Last Edit: 2018-05-21 02:07:13
| [2018-05-21 14:10:28] |
| @sstfrederik - Posts: 413 |
try this: =AND((H[-1]<=H[-2],L[-1]>=L[-2]),OR(C>H[-1],C<L[-1])) |
| [2018-05-21 14:24:42] |
"try this: =AND((H[-1]<=H[-2],L[-1]>=L[-2]),OR(C>H[-1],C<L[-1]))" I got this error message when I tried that: Alert Formula Error - Chart: MU 5 Min #29 | Study: IT | Error: #SYNTAX! | Formula: =AND((H[-1]<=H[-2],L[-1]>=L[-2]),OR(C>H[-1],C<L[-1])) | No alert sound/email. |
| [2018-05-21 15:02:37] |
Sorry. This one should work: =AND(AND(H[-1]<=H[-2],L[-1]>=L[-2]),OR(C>H[-1],C<L[-1])) Date Time Of Last Edit: 2018-05-21 16:02:14
