Date/Time: Mon, 20 Jan 2025 08:20:41 +0000
Adding VWAP to an Overlay chart...
View Count: 2165
[2018-05-20 15:38:49] |
User629089 - Posts: 93 |
Hi, I've set up an overlay chart with three symbols, CL, RB and HO in separate chart regions. In addition to the symbols, I'd like to add a Volume Weighted Average Price study to each symbol in their separate chart regions and not just for the primary symbol CL. RB and HO are added as the overlays. Unfortunately I don't think this can be done but wanted to check. Can a VWAP be added for each symbol? Thanks |
[2018-05-21 18:07:26] |
Add the VWAP study to the charts for each symbol, then use the Study/Price Overlay study to display the VWAP on the destination chart. You will find the documentation for the Study/Price Overlay here: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-22 05:00:37] |
Actually, it is possible to use the Add Additional Symbol study and base the Volume Weighted Average Price study on that. Refer to: Add Additional Symbol: Basing Other Studies on Add Additional Symbol In this way, you can eliminate the overlays. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-22 05:00:59
[2018-06-03 21:36:31] |
Hi, I have been able to use the "Add Additional Symbol" study and base the "Volume Weighted Average Price" study on that and it looks like it's good for symbols NQ and RTY. The problem now is that I cannot adjust the positioning of the bars in the 2nd and 3rd chart region with the mouse and "Ctrl" key for those symbols. They're froze and don't move at all now when the mkts are closed. It works fine for the original symbol ES in chart region 1. The same goes for symbols RB and HO in chart regions 2 and 3. CL in chart region 1 works fine. Any ideas here? Thanks... |
[2018-06-04 19:19:44] |
What you are referring to is Interactive Scale Range and Move. Refer to: Chart Scale and Scale Adjusting: Interactive Scaling There should be no problem with this. Make sure the Add Additional Symbol study is not using a logarithmic scale. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
