Date/Time: Fri, 07 Feb 2025 11:52:33 +0000
Print a year worth of charts
View Count: 1394
[2018-05-20 14:03:10]
Giamsterdam - Posts: 33
Is it possible to print a year worth of charts if yes how?
cheers,
giacomo
[2018-05-21 21:08:23]
Printing is supported but you can only print one chart at a time and what is visible on the chart. Refer to:
http://www.sierrachart.com/index.php?page=doc/FileMenu.html#ChartPrinting
[2020-06-02 15:10:57]
osaga - Posts: 53
Giacomo
You could consider using a program like "Snag It" from TechSmith that is a screen capture utility. This one in particular can capture a scrolling window... so you can load the chart for as long as you like and it will capture the entire window and auto scroll it so it captures everything contained within the window.
Regards
[2020-06-02 19:37:20]
There is a much much higher quality program than that. It is:
https://faststone.org/
It also can do what you describe.
Date Time Of Last Edit: 2020-06-02 19:37:46
[2020-06-02 20:06:19]
osaga - Posts: 53
Thanks for the recommendation. I'm always looking for better software. Snagit is ok I will give FastStone a go.
As far as trading platforms go... I have yet to find a better solution than Sierra Chart. And that's no joke.
Thanks again guys!
[2020-06-03 03:21:28]
We remember more than like 15 years ago when we started using a product from TechSmith for screen capture and recording, it just was so complex and heavyweight and confusing. And when we switched to Fast Stone, this was true quality simplified stable software. A world of difference. It is an excellent undiscovered program.
We remember the name: "Camtasia". That is a good example of just what we said. Complex, heavyweight, low performance, and confusing and whether it was stable or not is another question, we don't really remember.
The videos we produce are using Fast Stone Capture. It delivers everything that we need and it is just so fast and simple.
Date Time Of Last Edit: 2020-06-03 03:25:00
