Date/Time: Sun, 19 Jan 2025 23:21:25 +0000
out of memory...
View Count: 589
[2018-05-20 08:43:24] |
User30743 - Posts: 365 |
hi i am getting an out of memory error when trying to load chats for auto backtesting (using 32 bit only) is it possible that this Using DTC Server for Data and Trading in Another Sierra Chart Instance could help to solve the issue? or is it only for realtime trading, not backtesting? |
[2018-05-20 22:39:26] |
Yes an additional instance can help and can be used for back testing as well.
