Date/Time: Sun, 19 Jan 2025 21:55:17 +0000
Discussion of DTN IQFeed with SC/CTS4
View Count: 735
[2018-05-19 19:19:13] |
User832512 - Posts: 22 |
Hi, Would I be able to run 2 instances of Sierra Chart on my computer where 1 instance is connected to DTN and the other instance is connected to CTS while using DTC to pass custom symbols\indices from the DTN Sierra Chart instance to the CTS Sierra Chart instance in real-time? The use case for this is that I use some of the DTN proprietary indices in my trading analysis. However, I execute through CTS and would like to integrate these DTN proprietary indices into my trading algorithms and executions methods. All the best, |
[2018-05-22 04:26:03] |
This can be done and the method by which it is done is documented here: http://www.sierrachart.com/index.php?page=doc/FileMenu.html#FileFindSymbol_OpenChartFromAnotherInstance It does not involve the use of DTC. Although longer term we would have to look at supporting that. But you can still do it now as currently supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-22 04:26:19
