Date/Time: Sun, 19 Jan 2025 23:25:44 +0000
Transparency Level
View Count: 1318
[2018-05-18 21:35:57]
User294443 - Posts: 14
Hello
Is it possible to change the transparency of volume profiles in a Numbers Bars chart (Column 1 Background Type (Ln: 17) = Volume Profile)? I would like to plot it with less than 100% transparency. I'm using a Candlestick Outline (ln: 74) and it is tough to see it with full transparency on the volume profile.
Thank you.
[2018-05-18 23:12:00]
No, this is not supported.
[2018-05-18 23:16:41]
May I please ask you to add this functionality?
