Date/Time: Sun, 19 Jan 2025 23:24:48 +0000
market depth
View Count: 889
[2018-05-18 16:28:41]
User800612 - Posts: 2
i wanted to ask my trial account doesn't show Market Depth Historical graph and other setting in the DOM ARE NOT APPEARING like volume bar for Bid/ask size inside ( chart DOM settings)
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=19326
[2018-05-18 19:01:42]
The volume bars are controlled through the Show Volume Bars setting in Trade >> Customize Chart/Trade DOM Columns:
http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#ShowVolumeBars
In regards to the Market Depth Historical Graph study, the first step is to see if you have market depth data available for the symbol of the chart. Refer to:
http://www.sierrachart.com/index.php?page=doc/FileMenu.html#OpenMarketDepthWindow
Date Time Of Last Edit: 2018-05-18 19:03:33
[2018-05-18 20:55:28]
this is an example of it inside the dom
imageDOM.PNG / V - Attached On 2018-05-18 20:49:40 UTC - Size: 85.68 KB - 345 views
imageno show this guy.PNG / V - Attached On 2018-05-18 20:49:59 UTC - Size: 268.49 KB - 349 views
imagedom no2.PNG / V - Attached On 2018-05-18 20:55:08 UTC - Size: 280.05 KB - 356 views
[2018-05-19 00:23:09]
In the newer versions of Sierra Chart the way the volume bars for the market depth quantities are enabled is different and as documented here:
