Date/Time: Sun, 19 Jan 2025 23:24:11 +0000
MACD with color coded Histogram bars
View Count: 1560
[2018-05-18 16:09:10] |
User835355 - Posts: 2 |
Hi. I'm looking for a MACD indicator where the histogram bars change color based on a higher or lower bar than previous bar.
[2018-05-18 18:30:45] |
This can be done by using the Auto Coloring setting for study Subgraphs: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#AutoColoring Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
