Date/Time: Mon, 20 Jan 2025 04:00:30 +0000
PositionData.MaximumOpenPositionProfit
View Count: 871
[2018-05-18 15:54:26] |
User39772 - Posts: 311 |
Hello, is there a reasen if PositionData.MaximumOpenPositionProfit is always zero, even if the position was in positive territory. By the way: all other variables like Average Price etc. of object PositionData hold valid data. |
[2018-05-18 18:54:30] |
In the next release we will add these new members which are used in the Maximum Open Position Profit and Loss calculations, so you can determine what the problem might be: s_SCPositionData::PriceHighDuringPosition s_SCPositionData::PriceLowDuringPosition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-18 18:55:03
[2018-05-24 21:23:38] |
Thank you for providing that. Unfortunately these variables do not contain the respective price levels but invalid numbers when I add the variables to my debugger or use the message log. All other data like AveragePrice, Quantity etc. seem to be correct. |
[2018-05-24 21:37:33] |
I found that these problems show during live trading and not in simulation mode. The only thing I do is switching between: sc.SendOrdersToTradeService = false/true; and Trade Simulation Mode On/Off |
[2018-05-24 21:44:25] |
Unfortunately these variables do not contain the respective price levels but invalid numbers when I add the variables to my debugger or use the message log. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-24 21:59:25] |
s_SCPositionData::PriceHighDuringPosition s_SCPositionData::PriceLowDuringPosition Will be set to DBL_MAX if there is no position . Otherwise, they should be set properly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-24 21:59:45
