Date/Time: Sun, 19 Jan 2025 23:15:44 +0000
Customize Tool Color Selections in Right-Click Menu?
View Count: 2050
[2018-05-18 05:04:10] |
mosheikh1996 - Posts: 3 |
Hi, is it possible to change the color options that are displayed when you place a tool on a chart, right click it, and hover over the "Color" section? Currently there are spaces for 8 preset color options. I'd like to be able to change the options that are displayed in the menu. I've attached a picture of the menu in question. Thank you. Date Time Of Last Edit: 2018-05-18 13:34:55
[2018-05-18 18:03:56] |
Yes those can be changed. Refer to the following documentation: Chart Drawing Tools: Quickly Changing Colors / Line Style / Line Width Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
