Date/Time: Sun, 19 Jan 2025 23:22:23 +0000
Replaying the DOM
View Count: 1521
[2018-05-17 22:11:07]
User104854 - Posts: 457
I have followed the instructions on how to replay a DOM and I find that it only works with Standard Replay. Is that the only option? When I try to use accurate backtest mode or calculate every tick mode it does nothing. It doesn't seem like standard mode updates the DOM accurately. Any suggestions?
[2018-05-18 18:43:17]
All of the Replay Modes are fully supported in this case.
Just make sure that you stop the replay completely after changing the Replay Mode for the change to go into effect.
Also it is fine to use the Standard replay with the Trading DOM. It is not going to be any less accurate. You need to follow through the instructions here:
http://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ReplayingTradeDOM
Date Time Of Last Edit: 2018-05-18 18:46:19
